Hello all,
New to the forum and new owner of a 98 Air Nautique. The boat had been used in mildly brackish water for the last few hundred hours but always flushed. Open cooling system. Galvanized trailer. I'm going to be using the boat in a salty environment. I live in Jacksonville right by the intracoastal. So probably a split between ICW and the St Johns river.
My question is what all I should look at doing for corrosion prevention. I'm planning on flushing after every use with Salt Away as long as rinsing the boat thoroughly. I'm also going to be spraying the motor with corrosion inhibitor. What else should I look at doing? The rear motor mounts are showing some corrosion already. Thanks for the help!
Aloha,
Jason
Aloha,
Jason
