Bearing protector
  • bradie
    • Aug 2013
    • 6
    • australia
    • 94 sport nautique
    Bearing protector
    I have a dhl trailer to tow my Nautique which I'm having problems with it throwing bearing protectors only on the left front wheel. All I have changed is overhauling the brakes and repacking the bearings and now I have gone through 3 buddies on that wheel, the last one I tapped it on with gasket cement and 10mins latter when I stopped and checked, gone. Any help would be great, it's not getting hot but maybe pressurising? Thanks Brad
  • sodbuster88
    • Nov 2008
    • 368
    • Clayton, NC
    Does it have the castle nut / cotter pin? If so, check to make sure both halves of your cotter pin are properly bent back over the end of the spindle. I have seen extra long cotter pins used that interfere with the bearing cap. If not...check the mating surface where the bearing cap is pressed into for distortion, burrs...should have a good tight press fit.
    Peace..
    • Rick
      • Mar 2004
      • 1250
      • San Diego, Ca
      Here is a link to the company that makes them. I have found that they are a great resource and very friendly on the phone. http://www.ufpnet.com/Home/tabid/36/Default.aspx
      Nautiqueless in San Diego
      • 81nautique
        • Feb 2006
        • 257
        • Big Rock, Illinois
        • 2012 200 Sport 1956 Correct Craft Collegian Past boats 1955 Correct Craft Hurricane 81 Anniversary Nautique 1960 GlassCraft Ski Nautique #1
        I think you need to check the pre load on that bearing. If the hub is just a little too loose the extra slop can cause those protectors to fly off once you get rolling. Since you've recently repacked the bearings it seems a likely place to start.
        • xrichard
          • Aug 2008
          • 671
          • El Dorado Hills
          • 2023 G23
          Likely what 81nautique said. I had a similar problem once in the past...the hub was just slightly loose after a repack.
          Previous boats:
          2015 G23
          2008 SAN 210
          2002 XStar
          1995 Sport Nautique
          • bradie
            • Aug 2013
            • 6
            • australia
            • 94 sport nautique
            Thanks all for your help I will for sure be checking the hub tension on the weekend
