'06 210 SANTE Pumps breakers popping
  • 210 Hopeful
    • May 2013
    • 12
    • Katy Texas
    • 2005 210 SANTE
    When I use the belly (not port of starboard) to pump out tank, the fuse pops. If you use it to fill the tank, no problems. How do I fix this? Any ideas? I checked to see if the pump was warm, no that. Instantly I thought to post on PN.
    2005 210 SANTE
    2002 Bass Cat
    2012 F250
    • Sep 2026
    Probably a short on the hot for reverse flow. Are these ballast puppies or aerators?
    • 210 Hopeful
      • May 2013
      • 12
      • Katy Texas
      • 2005 210 SANTE
      I will have to check on that. I just bought the boat a few months ago.
      2005 210 SANTE
      2002 Bass Cat
      2012 F250
      • hotstreetvw
        • Apr 2008
        • 24
        Change the impellers. They have gotten hard and will cause high amp draw and trip the fuse. Even if they work in one direction and it trips in the other direction, its the impeller. I had similar problems on my 06 210. Changed all three impellers with the green ones from Nautique parts and it hasn't skipped a beat since.
