Hi all, once again I need some advice. I have posted this over on CorrectCraftFan aswel so sorry if you read it twice. I have got a 1980 Barefoot Nautique which has the 7.4 pleasure craft V8 which I believe is called the 454. This is the original engine that came in the boat and it is 100% perfect with no problems. The problem I have is that the Fuel prices in the UK are huge and so am burning around £80 per 4.5hour session which is about $136. I have spoken to a main agent about an LPG conversion which I am going to do but he has also offered me an engine conversion free of charge to the smaller Ford Windsor based unit which I think is a 5.7 V8 with a years warranty. This engine is a 1998 and so much newer but my question is will this engine burn much less fuel to make it worthwhile, and will the drop in performance effect me at all? I mainly wakeboard if that makes any difference. I dont run with any balast at the moment but am going to be adding quite alot soon and will the small engine still have the power with fully loaded balast?
Thanks
Thanks
