A couple of questions:
- Which direction am I to unscrew the PCM FCC? Is it traditional counterclockwise? I can get it to turn about 1/8 of the way either direction, but then it's VERY tight. Before I put more pressure on it, I want to be sure to be unscrewing it the correct direction (and not over tightening it by mistake).
- The directions on the side of the PCM FCC talk about draining water into a container. See the attached photo. The one other time I changed the filter, I unscrewed the PCM FCC being careful not to spill the gas inside and put on a new filter. I didn't do anything with draining water and have no idea where that water is since it's gas inside the PCM FCC.
I'd greatly appreciate your feedback.
Many thanks,
Jim
Many thanks,
Jim
