So the other day my son and I were discussing the gas mileage on our boat as this is the first inboard I have ever owned (a bit shocked at the pump) and we got to talking about ways PCM could improve fuel consumption. The main one we came up with is since the PCM's are built off of the GM platform we were wondering why they don't incorporate the "active fuel management" system that is in the new GM trucks. The system works by deciding how much power and torque is needed for the job and switches between 4cyl to 8cyl based on that. So if you are just cruising down the river with your buddies only going ~20ish mph you would only be running 4cyl which would A)cut gas costs tremendously and B)make the engine much quieter.
The other idea we came up with is to just simply put something like a two-stage transmission into the boats. So it could be geared-out really low when yanking somebody up out of the water but then once it got up to speed it would kick up a gear to lower the RPM's.
What are some of you guy's thoughts on this?
