My SN's engine is leaking oil at the rear main seal (RMS) (mild but persistent slick under the engine and a trail down the vertical face of the bell housing).
How difficult is replacing the rear main seal, on a difficulty scale of 1-10, easy-hard?
I'd need to remove the transmission to access the RMS, also the bell housing and flywheel - will I have to rig up a sling or some such to support the rear of the engine when the transmission is removed?
Since the engine-transmission assembly is supported with two mounts near the front of the engine and two mounts at the transmission, my concern is what happens when the engine is separated from the transmission - are the two front mounts alone sufficient to support the engine without damaging anything?
Any insights would be appreciated.
Thanks
-Dave
Thanks
-Dave
