Hi again everyone,
After removing the hard fuel tube/pickup from the tank, and cutting it off slightly below where it pushes on the 90 degree fitting, I re-installed it (by pushing it back on). I believe it might have expanded slightly over time, and was leaking slightly. Even then, I can see a tiny amount of air bubbles in the clear temporary supply fuel line I installed to the engine.
I ran it quite a bit this weekend, (and it didn't cut out on me at all), so I believe that was the problem. I still do plan to try to find some of this hard fuel line, to replace it eventually, but it seems good for now anyway.
This took a long time to diagnose (over the past year or more), so I want to thank you all for your advice. Running clear fuel line to and from the engine/tank had to be the best piece of advice I received, as it pretty much tells you what is going on in your fuel system from a flow standpoint. Once you can see what is going on you can then diagnose the cause.
Thanks again, and have a great 4th of July week on the water!!
Kent
Kent
