I’venever posted anything in the past and I’m an amateur mechanic at best but Iseem to have run out of repair options and my problem persists so I thought Iwould turn to others for help. I have a 1997 Ski Nautique that was bought newfrom the same dealer that has serviced it from the outset. Beginning twosummers ago, I began to have various fuel related issues and I’ve done thefollowing:
- replacedthe relays (intermittent stalling and problem corrected)
- hadthe fuel tank drained and the lines cleaned (stalling after a few hours of usewhich was diagnosed as a clogged screen in the fuel pick up at the tank)
- replacedboth fuel pumps (as a result of my current problem)
Mycurrent problem began mid-summer last year. The boat was used for a few hourswhile skiing without an issue. After an hour or two at the dock, I went backout at idle speed and made it about a ¼ mile before stalling. A few hourslater, the boat started and ran without an issue. A couple weeks later, samescenario (skiing, back to the dock then back out) but this time I was at 20-25mph, but again made it about a ¼ mile before stalling. The stalling was aresult of lack of fuel rather than an abrupt stall. This time, I lifted theengine cover for 10 minutes after which the boat started and ran fine. I couldhear the fuel pump in the fuel cell turn on each time. The same scenario hasnow occurred 6 times but lifting the engine cover for 5-10 minutes allows theboat to again start and run fine. Not sure what else it could be. Your commentand suggestions would be invaluable
