Ok, I am having trouble getting this theory through my head. I've had a little advice and I just need clear instructions on how to hook this up. 91 Barefoot/Excel, 454 pro tec with low pressure electric fuel pump. Factory alt was 50 amp (or just under) with the 50 amp breaker. Factory alt was toast (I'm restoring a boat I just got) New 100 amp certified marine (97 amp actual output) alternator was only about $15 more (and was even chrome! It's all they had) and is a one wire. Also just had the starter rebuilt by a very reputable starter shop that I've used before.
Do I run a heavy gauge (4 or 6 ga) from the new alternator output to the hot terminal on the starter, then from there with heavy gauge to the positive battery terminal? essentially by passing the 50 amp breaker? If so, then what do I do (if anything) with the existing #23 and then #22 from the solenoid mounted at the back of the intake. Do I put both #22's on the same side of the solenoid?
Should I get a 100 amp breaker, and where to install inline?
I know the starter cable should be at least 4 ga due to the high amp draw for starting.
I will be installing a Perko switch (with batt 1, batt 2, both, and off detents) with 2 batteries, relocating the batteries to the port side for better weight distribution and a shorter battery-starter cable.
Sorry if the attached diagram is sideways.... :/
I also need to get a slightly longer belt as this particular alt. is just a bit bigger and contacts the block when installing the belt. A longer belt will still allow for alt movement for belt changes without any other clearance problems.
Thanks in advance!
Thanks in advance!
