Ok so today I was pulling a wakeboarder (5th set of the day) and everything was going great until the engine shut off for apparently no reason. It was almost like the kill-switch had been pulled. We checked the kill-switch and unfortunately that was not the problem. When we tried to restart the motor everything sounded right and the vitals were all good but it wouldn't turn over. It sounded like it was either A) not getting gas, or B) the sparkplugs weren't firing. The fuel pump DOES work. Any ideas as to what the problem may be?
P.S. Do you guys know of an aftermarket 'scanner' tool that I can use to turn the check engine light off by myself. When I fix this I don't really want to drive around with my check engine light on.
