engine temps
  • H20SNOB
    • Feb 2013
    • 6
    • Lincoln, NE
    • 1999 ski nautique 196 OB
    engine temps
    what should normal engine temps look like? New ski nautique owner here, I see 160's thru 205-210. Dealer said it checked out fine "in the tank" so they didnt think I should have to worry about the impeller. When should I worry? Not sure when last impeller was changed 350hrs currently...1999 GT-40, thanks
  • 2001SAN
    • Apr 2012
    • 203
    • Ireland
    • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
    temp is 160 on my gt40. maybe a little less when running. never any higher. impeller is an easy change for piece of mind. also, carry a spare just in case. if it's ever been run dry it would be worth changing.
    d.
    • Fluid63
      • Sep 2012
      • 30
      • Australia
      • 2003 Super Air Nautique 210 TE 1998 SN 196 1977 Flight craft Phantom
      160-170 Deg F was normal for my 98 SNCB with Pro boss, and same on my 03 SANTE 330excal.
      • dfoster
        • Mar 2012
        • 134
        • Northborough, MA
        • 2004 SV211 TE
        I only hit the 205 - 210 range if I am running WOT for a while. It will definitely run hotter than 170 at that point. The only other time I ran that hot was when I had an impeller problem and it got up there at idle. The impeller was starting to go and at idle it couldn't quite pull enough water in. If I goosed it up and got the boat moving it would be okay and cool down, but I couldn't idle for long. Changed the impeller out and the problem went away.
        So i would agree with the others that if you are hitting 205 and it isn't because you are running flat out, then I would change the impeller.
        • H20SNOB
          • Feb 2013
          • 6
          • Lincoln, NE
          you guys are good, water temps are 160 with new impeller...Thanks!
          • shag
            • 2217
            once a year impeller change = good temps....
