Ballast pump not draining.
  • BlkCrkNautique
    • Mar 2013
    • 31
    • Middleburg, FL
    • 2006 Air Nautique 226
    2006 Nautique 226 with Jabsco pump will not run to drain the belly tank. Fills fine just won't turn on to drain. Easy fix?
    • Jun 2026
    Sounds like a loose wire on the switch to me.
    • BlkCrkNautique
      • Mar 2013
      • 31
      • Middleburg, FL
      The switch on the keypad? I guess I did leave it out but the light is blinking on the keypad like it should to pump out.
      • HS
        • Oct 2007
        • 1333
        • Sammamish, WA
        • 2010 SANTE 210 (Sold)
        I lost a pump replaced under warranty that had intermittent issues like not start. Would fill then decide not to empty...
        • Mark56
          • Jul 2007
          • 36
          • AU
          I would firstly remove impeller then switch on to fill you will see the brass guide that holds impeller spinning
          Then press to empty see if spins if it does impeller was jammed replace or repair
          If nothing happens then need to look at switch & wiring fuses
          Good luck mark
          • perry386
            • Jun 2012
            • 560
            • gadsden AL
            • Super Air nautique 236
            My pump was doing the opposite but i would be willing to bet it is the same problem. Open up the battery selector box in the engine compartment (the thing with the red dial) and try to drain the ballast and listen to which one of the little black boxes 'clicks' and then replace that relay. Not super hard but unplugging the relay can be a PITA sometimes. You can get the relay at O'reilly for 19 bucks instead of the 50 that Nautique parts will charge you BTW.
            • BlkCrkNautique
              • Mar 2013
              • 31
              • Middleburg, FL
              Ah...relay. Didn't think about that. Thanks.
              • Ksmit011
                • Jul 2013
                • 20
                • Ohio
                • 2006 210 super air
                I'm having the same problem with the starboard tank pump not working in the drain mode, 2006 SANTE. Anybody know where the relay is that controls the drain mode for the starboard pump?
                • Ksmit011
                  • Jul 2013
                  • 20
                  • Ohio
                  I opened up the battery box but did not hear anything when I pushed for drain. I have a 2006 SANTE.
                  • perry386
                    • Jun 2012
                    • 560
                    • gadsden AL
                    Try putting your hand on the relays and feel for a click.
                    • Bigdogsuperair
                      • Jun 2011
                      • 30
                      • Ohio
                      • 2018 G21 2007 220 Team (sold) 1999 Air Nautique Python (sold) 1988 Ski Nautique (sold)
                      I had the same problem last year with the belly tank. To verify if the pump will empty just unplug the power lead from the port pump (assuming it empties) and connect it to the belly pump. Then press the empty cycle on the port pump and see if the belly pump works. If so then it may be your dry run sensor.
                      • jkallen21
                        • Jan 2013
                        • 400
                        • United States
                        • 2006 Super Air 220
                        I posted earlier but don't see it here, my 06 SANTE has breakers for fill and breakers for drain under steering wheel at driver's feet. This is in addition to the main breakers at the battery switch.
                        • Ksmit011
                          • Jul 2013
                          • 20
                          • Ohio
                          Where are the dry run sensors?
                          • Bigdogsuperair
                            • Jun 2011
                            • 30
                            • Ohio
                            It is under the dash near the cup holder near the key pad.
                            • Ksmit011
                              • Jul 2013
                              • 20
                              • Ohio
                              Turns out that the relay was not the issue...after doing a little more research I believe the issue is with how the ballast system works on a 2006. I pulled the level sensor out of the tank and moved the float up to indicate full....the pump turned on in drain as soon as I did that. If the system thinks the tank is dry it turns off the pump in drain mode. Nothing wrong with the pump. I believe there is also a ballast tank controller on 2006 boats and later, anybody know where it is located and how it can be adjusted?
