I would replace the impeller and thermostat anyway. I bet that will correct your problem....
- Feb 2010
- 921
- Phoenix AZ
- 2013 G23 550 hp (ordered and awaiting delivery) 2002 Super Sport (coverted into a SAN) 330 hp Excaliber 1994 Sun Tracker Party Barge 115 hp 1989 Horizon 200 Four Winns - sold 1989 Regal Commodore 280 - previous Possibly looking into picking up a 70'2-80's Nautique to rebuild as a ski boat
Thank you all, the rubber was partially stripped from the metal housing. I could rotate the water pump and the impeller would turn at low speeds, but at higher speeds/rpms the metal would spin but the rubber part of the impeller was not. Replaced the impeller, some hoses that looked like they may be a problem in the future, checked the down stream hoses for previous impeller parts, and replaced the thermostat. Want the boat to work just as well for the new owner (if I decide to sell) as it has for me the last four years. Thanks again for all of the help to PN forumEric, Phoenix AZ
G23 550 hp (finally here)
2002 Super Air
