Hi, Would love to go boating...but...backfiring problem
1999 Ski Nautique
Gt 40 engine, PCM 1.23 :1 transmission
This winter, I had the engine rebuilt. (3500 hrs on previous one)
Engine (machine) shop put it back together up to the intake. They put distributor in, I installed plugs, wires, fuel injection parts, Computer, electrical.
I bought my new cap, rotors & plug wires from nautiqueparts.com
For spark plugs I used Autolite Platinum 2.
I set the timing @ the lake per instructions: 5 degrees BTDC in neutral @ 2000 RPM with the SPOUT plug removed
At the lake, in neutral, the engine runs well and responds as expected 600 - 4000 Rpm.
I am not quite sure the bracket that holds the throttle cable and bolts to an intake bolt is in exactly the right position. By tweaking it slightly by hand, I can change the idle down to where the engine stalls out, or alternatively I can increase it over 1000
If I idle at around 700-750, When I shift into forward gear, it wants to stall. If I give it a little bit of gas, I can keep it running.
If I slowly increase the throttle, things seem normal until about 1100-1200 RPM. At this point, I get backfiring.
I do not have the black rubber boot (distributor cover) installed yet. I was waiting until after I set timing. A local mechanic suggested this may be my problem, as arching was "a known problem with that distributor, and the rubber boot is to reduce / eliminate that"
Transmission (in case this is relevant?) The transmission is basically new. Got a new one that had been sitting around for a few years at a price that worked for me. Seems to work fine. The painting plastic plugs were still in it. Sadly I broke the input shaft on my old one which worked great by pulling the engine up too soon when removing the engine.
While driving the boat, I tried manually adjusting the distributor timing by hand with the SPOUT connected. There was no position for the distributor within the reasonable running range that improved the 1100-1200 RPM backfire.
I also tried giving it more throttle when it hit 1100 and it seemed like it really did not want to open up and go.
Last winter, (while disassembling the engine prior to rebuild) I accidentally grounded the main battery connection on the bottom of the computer to the engine block for less than 1 second. Did not expect it to be live with ignition button not on. My bad. Would this have damaged my computer causing my current backfire problem?
Tomorrow, I will drain the fuel out of the FCC to see if it happens to look watery and investigate the "small clear hose" inside the FCC that is reported to crack occasionally? I read a post where someone was getting backfires for about anything above idle when this hose was cracked.
Any suggestions as to what I should investigate? It seems odd that the backfiring only happens under load.
Many Thanks for reading.
Dave
Springdale, UT
1999 Ski Nautique
Dave
Springdale, UT
