steering cable
  • johnboyy7
    • Oct 2009
    • 409
    • houston
    steering cable
    mine is a bit stiff. is there anything i can do to loosen it, other than replace?
    04 SANTE 210
    89 SPORT
  • JayG80
    • Dec 2006
    • 215
    • Santa Fe, TX
    • 2007 Ski Nautique Sold 2002 Ski Nautique
    Sometimes greasing the rudder will help. You can disconnect the cable from the rudder and see if the steering is still tight. If that doesn't help then replace the cable.
    When I finish using the boat, I always turn the steering wheel all the way to the right so less of the cable is exposed to the air.
    • LakeRats
      • Jun 2012
      • 50
      • North Carolina
      • 2012 Sport 200V
      Try greasing steering components, but will probably have to replace cable. You may be surprised at how stiff it has actually become compared to new cable
      • s_kelley2000
        • 1582
        • Fort Meadow Recevoir
        • Mass
        Was it the first time out for the season and/or was the weather cold? Both of those can lead to the steering feeling stiff and it may loosen up a little. Try turning lock to lock a few times before you get moving and see if that loosens things up at all. If it is still the original cable from 04 then it likely will need to be replaced sooner rather than later but it may free up some for you once it warms up and gets a little more use.
        Shawn
        2012 Blue Metal Flake SAN 230
        • johnboyy7
          • Oct 2009
          • 409
          • houston
          its for sure stiffer than a new one. it takes both hands when under power. its considerably easier when sitting still.
          04 SANTE 210
          89 SPORT
          • jbach
            • Aug 2012
            • 187
            • the state, not the jelly
            • 1999 SAN
            you need a new cable. mine was doing the exact same thing the end of last season. i have a new cable ready to go in this spring, if it ever gets here.
            • ski4evr
              • May 2010
              • 613
              • Bowling Green, KY
              • 2005 SV 211
              You won't believe the difference in a new cable. Mine got progressively worse without realizing it. finally it go to the point when under power it took two hands to turn. Now, a couple of fingers will suffice. feels like a different boat. Just wish I had replaced the hydro gate cable while in there. Starting the same thing.
              2005 SV-211
              • H20SNOB
                • Feb 2013
                • 6
                • Lincoln, NE
                • 1999 ski nautique 196 OB
                Is replacement a major job or can it be done fairly easily?
                • jbach
                  • Aug 2012
                  • 187
                  • 1999 SAN
                  not too bad of a job. when pulling the old cable from the helm, tie a rope to the rudder end, then tie rope to new cable and pull back through. it probably won't go without getting hung somewhere but it will help.
