No oil in drain tube
  • AirTool
    • Sep 2007
    • 4049
    • Katy, Texas
    Originally posted by shawndoggy View Post
    What about the oil that was in the filter? Do you funnel that into the 5qt bottle too?
    No. But I'm never more than 1 qt low to start and once I warm it up on the water, I fine tune the level to about 1/4 qt low.
    • AirTool
      • Sep 2007
      • 4049
      • Katy, Texas
      Originally posted by xrichard View Post
      then get a fitting for the pump that matches to the one on the boat drain hose. When you get home from using your boat, hook up the pump while everything is still warm.
      I use this fitting because the nut spins which makes it easy to put on. When not in use, I thread in a hex plug. Its 12 bucks from grainger.
      • AirTool
        • Sep 2007
        • 4049
        • Katy, Texas
        The suck up is available from nautique parts and its 10% off with our PN discount.
        http://www.nautiqueparts.com/asuck-uppump.aspx
        • JayG80
          • Dec 2006
          • 255
          • Santa Fe, TX
          • 2007 Ski Nautique 2002 Ski Nautique 1999 Moomba Outback
          http://www.northerntool.com/shop/too..._390306_390306 this one works just fine.
          • jsta281
            • Oct 2012
            • 266
            • Utah
            • 2009 Ski Nautique LE
            I just ordered the liqiivac
            Looks pretty slick 54 bucks
            • jsta281
              • Oct 2012
              • 266
              • Utah
              #21
              That's a great idea, if you swiped that pic of their website can you post a link or part #?
              • Quinner
                • Apr 2004
                • 2246
                • Unknown
                • Correct Crafts
                #22
                Suck-up does not suck! Best type I have ever owned, mine has got to be close to ten years old, works great on boats, cars, trucks, whatever.
                I will usually draw out the dipstick first and finish from the drain hose
                • gtxragtop
                  • Oct 2011
                  • 56
                  • Worcester
                  #23
                  Taking the cap off does not matter at all. Engine crankcases are not sealed. There is a PCV (positive Crankcase Ventilation hose that connects to the intake manifold that sucks air and fumes out into the engine and burns them. There needs to be an open hole to the atmosphere to let air back in. This is typically the hose from the valve cover to
                  the air intake screen/filter/flame arrester.
                  • AirTool
                    • Sep 2007
                    • 4049
                    • Katy, Texas
                    #24
                    Originally posted by Quinner View Post
                    Suck-up does not suck! Best type I have ever owned, \
                    I agree, it appears far superior to the others. The only dislike about mine is the height to diameter ratio. It is a bit tippy so I always have it in a dedicated 5 gallon bucket. Not a big deal because it helps contain any mess or residue from other jobs and ensures my carpet stays clean. I've now built several threaded tubing adapters for various tasks.
                    The only thing I could think of better would be to have a separator only device with a vacuum connection w/a hose running into my garage and directly connected to my yellow jacket vacuum pump. Better yet, maybe a small propane tank w/a 3-way valve at the top and pull a full vacuum in advance. I think that would be enough to pull 5 qts of oil.
