I don't think it would be critical to remember to retract. The tabs in general will just raise the back of the boat and remove the wake. If you left one side extended and then sped up it would probably quickly become obvious and you would just continue on - without slowing - and retract.
I am relatively certain that someone that understand electricity better then me could use the control unit/wires from volvo set up with tabs from nautique and have an easy time of it. The nautique system is just one tab on each side. So should easily retro fit somewhat with volvo set up.
Option one is nss tabs with volvo electronics setup. This is nice in that control panel would tell you how far in/out they are.
Option two is full on volvo set up...Not as pretty for sure.
Option three wait for nss to become more broadly available.
