Hey Guys,
Just recently we noticed that the security code process is no longer working properly.
If you have entered the code, it doesn't reset even when you switch to "all off". You can simply switch from "all off" to "all on" and hit start without having to enter the code.
Also the dead man switch doesn't seem to work.
Wiring is all factory as far as I can see, and the only changes made is the stereo has the ipod connection mod done and a new sub amp installed.
We only noticed it recently shortly after the boat momentarilly shut down whilst on the water - Nothing worked for 20 seconds or so, then it came good.
Any ideas.?
Any ideas.?
