Lake level fluctuates a lot where I live very low in late after noon due to electricity being generated when I try to put my boat on lift the three fins hit crossbar would it have a dramatic affect on handling if I remove the fins changing the lift is not an option at this point and the level is low from 4pm until next morming
Removing the fins is not an option. Not only will the boat not handle as it was designed it could create a dangerous situation if turning at speed.
Many lifts have the option or come standard with the back cross bar in "V" which gives additional clearance for the fins. This would be an easy fix if your current lift has a straight crossbar.
Move the lift into deeper water. Depending on the slope it might only take a foot deeper to gain clearance.
Dig out under the rear pads of the lift. Again, it might only take a couple of inches to do it.2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
