Okay, so the last few times I have had the boat out, when emptying the bilge I have seen the tell tale sign (rainbow) of gasoline in the water exiting my bilge. It seems pretty dilute, in that I cannot smell it, but I can see it. I have checked the obvious places for leaks like the Fuel Control Cell (top and bottom) and the fuel rails. Any other spots the great PN brain can think of? I guess I have not checked the line from the gas tank to the fuel control cell and will do so. But is ther anywhere else? Is there anywhere toward the bottom of the engine that could be the culprit? I do not see gasoline leaking from anywhere visible when running the engine.
Also, I am fairly sure it is coming from bilge, but I suppose it could be coming from my exhaust. I have not scientifically checked yet, as I always open up the drain plug right when I pull the boat out. I will test it on the next outing scientifically (although I am a bit nervous about getting all blowed up if I don't find this leak before taking it out again). Is is possible that I could be leaking gasoline out of my exhaust?
Note, the boat runs great... although it did stall once while idling for an extended period the other day. This is the first stall since replacing my distributor last August.
Scott
Scott
