Hello All,
I am in the process of adding a tower to my 1992 Nautique Excel with a closed bow. The tower manufacturer recommends that the glass be at least 3/8" thick. The only place I ran into a problem was on the passenger side front tower leg. It needs to go in a spot that it not very thick or reinforced well (next to the cleat). I have ditched the factory provided 3-1/2" X 4" backing plate and cut/fit a 3/4" thick oak board and a 1/4" thich steel plate to use in place of it. The oak board is roughly 6"x 9" and the steel plate is 4" x 7". I still feel that I should add a couple layers of fiberglass just to be safe. I purchased a fiberglass kit from Napa that included the cloth, resin, hardner, etc. After removing the foam and cleaning up the surface underneath the bow I cut 2 pcs of cloth to fit and mixed the resin and hardner. I laid the cloth flat on a couple sheets of waxpaper and spead out a nice layer of resin. I soon realized there was no way I was going to be able to handle the size of cloth with resin that I working with. I was on my back attempting to lay it in place overhead and it didn't work. I discarded it and quickly cut a smaller piece approximately 8" x 12" and repeated the process. This time I had no problem getting the piece in place but it would not stick/hold. I thought for sure the resin would hold the cloth to the undeside of the bow but I was wrong. I called it a night after this.
Can anyone offer any advice? I've spent the last 2 hours searching for information online and the only thing I can see trying is applying the resin to the underside of the bow first and then laying the cloth up there and adding additional resin if needed.
I won't see the boat for a couple of weeks now so I want to make sure that I am prepared to finished my tower install the next time I am at the lake.
Thanks in advance!
Adam
Thanks in advance!
Adam
