Is there a Napa part number equivalent for the 3/8" inline fuel filter used on the EX343?
I'd really just like to walk up to the Napa counter. They are pretty fast too. Like "here ya go" fast.
Part numbers are in engine manualAttached Files
MAINTENANCE ITEM PART NUMBERS:Description Part NumberOil Filter R077001KitExhaust Service Kit, 5.0/5.7L, MP engines only RP173091
Transmission Oil Filter (ZF) RP077011
Fuel Filter, Primary R080024
Fuel Filter (FCC), Kit RP080026
Spark Plugs RP030010
Spark Plug Wire Set RK120018
Spark Plug Wire Set, CES RK120023
Serpentine Belt R066028
Impeller Kit (Serpentine Raw Water Pump) RP061022
Oil Drain Kit RK024179
http://cdn-1.psndealer.com/e2/dealer...orts/2008p.pdf
Attached FilesLast edited by scottb7; 07-12-2012, 12:20 PM.
The NAPA 3482 filter appears to be a the spin on model not the inline filter.
So I went to the local nautique dealer and purchased there. Oh well, the couple extra bucks keep a local boat shop open.
That is the correct Napa # It's the one I used
http://www.napaonline.com/Catalog/Ca...482_03313563382008 210 SAN TE (Moonraker Yellow over Midnight Blue)
