OMG got very lucky but now what(drive shaft seal) NEED HELP
  • sjames
    • May 2009
    • 219
    • California
    I was checking everything out before we head to the lake and I notices my port side air intake how was half gone? Hmmmm aliens?
    Nope somehow the other end near the drive shaft.... yup the drive shaft...!!!
    So after 2 hours of **** in the hot sun I manage to get the thing unwrapped(see picture can't attach video but here is a PICASSA link)
    https://picasaweb.google.com/1107725...00651301250962
    Now for the question I have a watercooled shaft coupler. I can now shove it to the size maybe a 1/4 inch and water pours out? Is this right? The clamps are tight and it is up against the coupler.
    It may be normal but not sure as I alway thought these were sealed and drained the the water through the seal? Of course underway they won't get shoved to the side so maybe I am ok?
ID:	376996Click image for larger version
    Heading to the lake Tuesday for a week of fun and would like advice is this normal do I need to take the boot loose and pull it forward.
    Any advice from the best boat owners in the word is much appreciated.
    Pics and video are attached.
    Do the right thing.......
  • sjames
    • May 2009
    • 219
    • California
    Follow on I saw this pic on another thread. Is is possible i just need to slide that coupler down to compress everything?
    • sjames
      • May 2009
      • 219
      • California
      Bruised, cut and tired I gave up.....
      I figured out the collar has two set screws and that it needs pre-load i.e. it needs to be pushed against the bellows. This is an easy feat on a bench or a direct drive but under a v-drive in a 220 is a nightmare. I got the allen's loose I got a small ball peen and tried to tap it closer to the bellows. I think I got 1/8" closer but in a ridiculous position and not much throw to hit the collar.
      I started it up and no major leaks so I'll give it a whirl still soem play if I grab the supply hose and push however. If anyone has idea on how to preload that collar send me a note.
      cool video showing basics of the Dripless shaft ( no way to get the 1" of compression in stalled ;-)
      http://www.youtube.com/watch?v=3UvyF...layer_embedded
