This weekend I took the boat out on the water and noticed that the volt gauge was reading at 11 volts and would not get any higher when the RPMS increased. After about an hour of run time, the boat began to spit and sputter and would only idle in gear. Then of course the boat stalled due to the batteries were completely drained. This year I did change up my set up by adding a Perko battery switch and I did relocate my two batteries..
So after being towed back to the landing, I took the boat home and charged both batteries, fired up the boat and checked the volt output while the boat was running. I was showing on the voltmeter at the batteries 11.8. So I am assuming that my alternator went south. I did verify that the 50 amp breaker was not tripped.
Any other things that I might be missing?
Thanks.
Thanks.
