worked perfect for about 45 min than stumbled and came to a erratic idle. opened engine hood while still running and sounds like air sucking everywhere. engine would not accelerate but would still idle, but not smooth.
1 shut engine off , restart and ran for 2 sec and died.
2 tried this for for five times. same results
3 after 2 -3 min started and i ran it down the lake at wot for several 10-15 blasts, came to idle and seemed fine.
4 pulled a wake boarder after about 10-15 same thing , power cut off, came to erractic idle, pops and then died on its own.
5 after about 5-7 restarts over about 5 min got it running and went to load on trailer ran fine , then died while in idle position on trailer.
6 got home, removed ffc (fuel fitler canister), perfect clean with zero water or dirt.
7 ran in driveway with hose and bucket at idle for 20 min with no problems
8 fuel filter is clean with about 50 hours.
9 i drained ffc and pump does fill it.
tought for sure it was going to be a water issue, but is not.
the boat is 6.0 liter zr6 2005 in a 196 ski.
what are most common issues with this engine.
i also disconnected the fuel pump on the egine while running in driveway-motor ran perfect at idle for 10 min
i then disconnected the with connector on ffc and it shut off within 2 seconds, but it did not sound the same as it did on the lake. it just shut off like you hit the stop button.
how do i go about fixing this.
