Ok so I can switch the toggle to the down positon and get the bildge to kick on, but when I flip it up to the ALL ON postion there is no power. I removed the panel with the toggle switch and found what looks to be as if two wires have broken off....is this my problem?
How ironic! Just encountered the exact same issue as your describe on a 2007 220. Bildge light comes on in down position but nothing when I toggle to all on. My switch looks exactly like the picture you posted. Any luck figuring out what the problem was?
I'm having similar issues on my 01 San. Bilge light will come on. But nothing else will. And randomly they will all work. Someone told me it could be a bad solder joint. Any help is appriciated !
The lug has broken loose inside the switch housing. Sometimes it will work....sometimes it won't.Originally posted by Agent banks View PostI'm having similar issues on my 01 San. Bilge light will come on. But nothing else will. And randomly they will all work. Someone told me it could be a bad solder joint. Any help is appriciated !
You need a new switch.
The switches are fine I used the 10 amp from my heater and prob still exist ? I think there may be a cold sauder joint in the starboard panel! Remember all the buttons work or don't work at periodic times. And I checked all switches. I'm baffled. It looks like there is no way to take apart the panel. Once again any info Is a help
you dont think it could actually be the key pad? a relay makes sense. the only place they could be is in side the wiring harness. both key pads use the same harness so i hooked my start pad up to the starboard harness and every thing worked so i know it from the plug on the panel side up which gives me very little wire to look through ha... do you think i can find a used key pad or do i need to buy a new one?
You should start a new thread and maybe somebody with your generation system will be reading.Originally posted by Agent banks View Postyou dont think it could actually be the key pad? a relay makes sense. the only place they could be is in side the wiring harness. both key pads use the same harness so i hooked my start pad up to the starboard harness and every thing worked so i know it from the plug on the panel side up which gives me very little wire to look through ha... do you think i can find a used key pad or do i need to buy a new one?
Coincidence, not irony.Originally posted by Bucks89 View PostHow ironic! Just encountered the exact same issue as your describe on a 2007 220. Bildge light comes on in down position but nothing when I toggle to all on. My switch looks exactly like the picture you posted. Any luck figuring out what the problem was?
