I have a 1998 SNOB. It's equipped with a 5.8 PCM. I changed the impellor, gasket and o-ring for the season.
Yesterday on the river I was testing her out when it started to overheat while idling out of the no wake zone.
Once I got to the upper speeds 25+ the engine cools down and operates at normal range. I pressure tested the water pump and it's properly sealed. I also checked all of my hoses and they seem to be good as well as the strainer. Any thoughts? This is driving me crazy.....
Also there is a black metal tube that is mounted next to the engine where the intake water hoses run into. Anybody know what these are??? Thanks in advance.
