I have a 2001 SAN and the back hydraulic lift engine hatch pump went out. Does anyone know where I should take this to get repaired or also had this problem?
RE: Hydraulic Engine Hatch
Talk to your dealer about getting a new one. They aren't cheap but they are pretty easy to install. Are you sure it was the lift engine itself though? Check the fuse and the breakers first.
Correction - I have a 2000 Super Air Nautique. Yes - checked the fuse and breakers. I will talk to my dealer, thanks!
Re: RE: Hydraulic Engine Hatch
Would you like me to change your username to Molly_2000SAN ?Originally posted by Molly_2001SANCorrection - I have a 2000 Super Air Nautique.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Nothing gets by you jeff. Touche!Originally posted by NautiqueJeffWould you like me to change your username to Molly_2000SAN ?Originally posted by Molly_2001SANCorrection - I have a 2000 Super Air Nautique.
Molly, I see you joined today. Welcome to the Planet.
RE: Re: RE: Hydraulic Engine Hatch
Yes, actually - I would love for you to change my name to Molly_2000SAN. I don't know where my brain was when I signed in. Wishing I had a 2001 I guess! Thanks for welcoming me!
Re: RE: Re: RE: Hydraulic Engine Hatch
Consider it done.Originally posted by Molly_2000SANYes, actually - I would love for you to change my name to Molly_2000SAN. I don't know where my brain was when I signed in. Wishing I had a 2001 I guess! Thanks for welcoming me!Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Hey I had a problem with my lift too. I checked everything out and finally decided that it was the actuall 6 pin switch that controls the lift. So check that and make sure everything on that is connected and that it works.if con is the opposite of pro, is congress the opposite of progress???
I may have the wrong terminology. There are 2 arrows by the dash that when you press, lifts the back cover up and down. Now all it does is click and doesn't raise the cover or lower it. I don't think they have this after 2000, since they went to the 3 piece back instead of 1 piece, but I could be mistaken....
Your right Molly...
But what Polkaking said, check the connections first. Try to connect the elektromotor directly (with another fuse line) on the battery. So disconnect the hydraulic from the normal circuit and connect does 2 wire to the battery power.. If the arm still doesn't move it's really broken, but this hardly ever happens...230 with ZR6 running on propane
