Okay, I tried searching but kept getting errors, so I will post my question.
Yesterday I tried to pull my prop using an acme prop puller. No dice. The thing would not budge. I remember reading that you can heat up (either the shaft or prop) with a torch, and the metal expansion will break it loose. However, I do not recall which I am supposed to heat up (the shaft or the propeller). Anyone know?
Also, I can't easily drop the boat in the water and run the prop in reverse for a few seconds (which I understand is another way). My boat is in dry storage presently.
Thank you in advance.
