Specific ballast install question for users of 3/4" thru-hull intakes
    • Aug 2026
    I am soon going to tackle my ballast install project on my 2000 SAN, and I am considering using individual 3/4" thru-hulls for each of the 3 Johnson pumps (as opposed to my orginally planned 1.5" thru-hull and manifold (thing is huge)). However, for those of you who have done this (as opposed to using 1" intakes or a manifold with 1" lines), I have a few questions:
    1. Were you able to get the 3/4" hose around the Johnson pump intakes? I remember that 1" hose was not terribly snug or hard to get on, so I think this might work. I do not have the materials at my house (they are 70 miles away), so thought I would ask the PN brain.
    2. What size did you use on the outflow side of the pumps? Presumably 3/4" also. I ask because I already planned this for 1" between the pumps and the bags and have the hose and fly-high fittings for 1". I'm not sure that having 1" lines between the pumps and the bags is a good idea. I'm not worried about it not being faster than 3/4", I understand the bottle kneck issue of using 3/4" thru-hulls and lines to the pumps. I'm just trying to figure out whether I need to return/sell my 1" fittings and sell my 1" hose, or whether I can use it without causing any problems.
    Thanks.
    Scott
  • GC
    • Sep 2003
    • 54
    • Tampa, Fl
    I have 3/4" thru-hulls used a 3/4" to 1" adapter on the ball valves.
    • seth
      • Jun 2008
      • 549
      • Santa Barbara, CA
      • 01 SAN-sold
      i also used a 3/4" to 1" ball valve.
      • vanislwake
        • Apr 2010
        • 113
        • 2001 Air Nautique 2000 Air Nautique 2003 Super Air Nautique
        3/4" thru hull 3/4" ball valve then a 3/4" to 1" hose barb fitting , 1" hose to pump and 1" hose from pump to bag.
        Current '02 sante full '06 updated
        Previously owned:
        07 San 210
        05 Sante
        03 Sante
        01 San 210
        02 Air nautique
        00 Air nautique
        + another 15 non nautiques
        • crobi2
          • Dec 2010
          • 337
          • Texas
          • 2000 Super Air Nautique
          A 3/4" NPT threaded nipple will fit snug inside 1" hose without any adapters. Just hose clamp it and you're good to go.
          It has about the same id as a 1" hose barb.
          Rob
            • Aug 2026
            Thanks all. Soon the fun begins.
