Current Jabsco Ballast Pumps
  • youngunz
    • Mar 2011
    • 150
    • Barrie, ON
    • 2002 SAN
    With the winter months now upon us and the boat in the shop, I was hoping someone could help me out with a pretty easy ballast pump inquiry. For those of you with newer model SAN, I was hoping to get a little information on the reversible ballast pumps that are installed. The plumbing in my '02 SAN needs upgrading, and instead of having fill & empty pumps, I was hoping to install one that can perform both actions.
    Model numbers, spec sheets, any information on what model I should consider would help.
    2002 SANTE
  • seth
    • Jun 2008
    • 549
    • Santa Barbara, CA
    • 01 SAN-sold
    http://www.wakemakers.com/jabsco-bal...oard-pump.html
    • vanislwake
      • Apr 2010
      • 113
      • 2001 Air Nautique 2000 Air Nautique 2003 Super Air Nautique
      I'd go with the johnsons, cheaper and faster!!! wakemakers is the only place to buy this stuff unless you prefer to spend more money, lol. they ship to canada too. drill another hole or 2 in the hull make sure you put in a ball valve, good luck, ive done many custom ballasts, and i am actually doing an 02 sante in the next couple months.
      Current '02 sante full '06 updated
      Previously owned:
      07 San 210
      05 Sante
      03 Sante
      01 San 210
      02 Air nautique
      00 Air nautique
      + another 15 non nautiques
      • mastercard
        • Jun 2011
        • 54
        • Tyler/Carthage Tx area
        Ditto on the Johnsons!
        2004 SANTE
        2000 SAN Sold
        • GC
          • Sep 2003
          • 54
          • Tampa, Fl
          The Johnsons are a bit faster but they don't come with a switch or the preferred green impeller like the Jabsco does.
          • vanislwake
            • Apr 2010
            • 113
            The cost of switches is still less than buying jabscos and as for the green impellers they do of course work in the Johnson's but I prefer the regular black ones and know alot of people will agree as the green ones have been known to jamb up quite often more than the black
            Previously owned:
            07 San 210
            05 Sante
            03 Sante
            01 San 210
            02 Air nautique
            00 Air nautique
            • youngunz
              • Mar 2011
              • 150
              • Barrie, ON
              • 2002 SAN
              Is there one Johnson model preferred over another??
              2002 SANTE
                • May 2026
                Ultraballast pump is the Johnson you want. It is the only one they sell on wakemakers.com.
                If you reverse the switch right at the end for just a second, you will increase the life of your ballast impellers significantly.
