Took the case of NAPA 40W back and exchanged for the VR1 40w. Ouch... Stuff aint cheap!
I miss the "sure grip" feature.Originally posted by AirTool View PostWell it was probably the decade when the FRAM filters was owned by Dana/Spicer heritage IIRC and quality was top. Now I think it is separate and run by bean counters and most of the orange stuff is from China...including the industrial stuff. A sad day for the color orange...one of my favorites.Current: 2001 Air Nautique GT-40
The least important feature of a oil filter is some gimmick that has no effect on how well it works.
If you cannot get an oil filter off easily with even a cheap oil filter wrench you are putting it on too tight.
You can get USA made genuine Motorcraft FL1-A oil filters at Wal-Mart, for less than $4.00 here in Oregon. I assume the price is about the same elsewhere in the USA.
Shell Rotalla T
I emailed Shell and asked them if 15W-40 in my 96 Nautique with flat tappet cams was acceptable. They stated yes. Oddly enough, they stated to stay away from straight weight oils.
Seems like Rotella T and Valvoline VR1 are very close to each other in zinc and phosphorus. Plus shell claims that other additives in this oil reduce cam wear better than the previous version that had higher zinc/phos.
Note: I pulled this note below off the web.
"I thought I'd e-mail Shell and ask what they claimed. Here's what they said:
"Shell Rotella T Multigrade Oil SAE 15W-40 with Triple Protection Technology, our API CJ-4/SM specification product, typically contains about 1200 ppm zinc and 1100 ppm phosphorous as manufactured.""Last edited by gtxragtop; 12-04-2011, 08:21 AM.
What do you think almost any company would say, "No, our product is not suitable for your use"?
PCM has said to use the straight weight 40 oil in the GT-40 engine. There must be a reason why. Can you use other oils? Sure, you can. It is your engine. But I will choose to take the advise of the engine supplier, especially when it does not involve something involving their direct sales.
You will note that my statement concerning weight was that Shell suggested NOT to use straight weight of THEIR oils for this application.Originally posted by DanielC View PostWhat do you think almost any company would say, "No, our product is not suitable for your use"?
Back in 96 there was plenty of zinc/phos in the oils when PCM made oil recommendations. I'll drop a note to PCM and see what they have to say.
You are missing my point. You are taking advise from a person who is essentially a salesman. their livelihood, and salary depends on selling their product. Of course, they will tell you to use their company's product.
Get advise anywhere you want. But consider, some opinions may be biased, not in your favor, if money is involved.
Surprised no one here has mentioned Joe Gibbs oil.
I use VR1 in the race car. I buy cases when it is 25% off at NAPA.
Just saw a press release from Quaker State saying they are bring out a high zinc oil.Doug
2014 230 Super Air Nautique
2008 210 Super Air Nautique (sold)
2003 216 Air Nautique (sold)
Lighten up. The grip was ingenious and allowed the filter to be removed by hand even when oily. I think we've all agreed Fram's days are over.Originally posted by DanielC View PostThe least important feature of a oil filter is some gimmick that has no effect on how well it works.
I agree on your Motorcraft comment. But some trivia you might be interested in....you've noted before that Motorcraft filters must be good because they are spec'd out and used by Ford, etc or some variant of that. This year I bought a new 2011 Ford and last year I bought a new 2010 Ford. Neither of them came with a Motorcraft oil filter. Both filters were white and unlabeled and the wrench crimping matched that of the non-Motorcraft variety if you know what I mean - not Motorcraft - so they probably were not the same spec.
came across this. didnt recall seeing this posted before...
need more zddp? zddplus
http://www.youtube.com/watch?v=1Zt6m6fRxDkCurrent: 2001 Air Nautique GT-40
No, Motorcraft filters "must" be good because theyve been dissected, and found to have decent filter media and anti-drainback valves. The same reason why Frams are no longer considered very good (proof).Originally posted by AirTool View Postyou've noted before that Motorcraft filters must be good because they are spec'd out and used by Ford, etc or some variant of that.
The levels of zinc/phos of the Rotella-T 15w40 (1200/1100 ppm) are pushing what Ive read to be the bare minimum to use on a flat tappet motor. I used to be a big fan of the Rotella, but now choose either 20w50 VR1 or 15w50 M1, as both are in the 1300/1200 ppm range.1990 Ski Nautique
NWCT
Please provide links to data from the manufacturers to back up this data. Otherwise, it is folklore as these vendors are continually changing there specs. Another spec that oil vendors provide that piss me off is the ACEA spec. They DO NOT tell you which year they refer to when they say for example ACEA-A5. There is a 2008, 2007, 2004, 2002 spec for A5 and the later year specs are more stringent. This is an interesting tool to compare oil specs.Originally posted by TRBenj View PostNo, Motorcraft filters "must" be good because theyve been dissected, and found to have decent filter media and anti-drainback valves. The same reason why Frams are no longer considered very good (proof).
http://sas-origin.onstreammedia.com/.../pc/index.html
Looking at the Valvoline MSDS sheets for VR1 (need to figure out which SKU number) ZDDP is >=1-<1.5%
See http://msds.ashland.com/msds-ext/msd...SearchHC&id=20
Premium blue diesel 15W-40 is >=1.5% -<5% zinc compounds. See http://msds.ashland.com/msds-ext/msd...SearchHC&id=16
So your better off with Rotella T 15W40 than VR1 if the Rotella T data is valid.
