Electrical checks out. Once in awhile it might sputter, but will never start. Any ideas?
I'm with swc. I had a similar situation this year. When you put in the code and his start twice can you hear the pump prime up. If not take a tool and tap the pump and see if you can get it to prime up. Either way you are going to need to replace it if it's not priming. I changed mine out a month ago. 150 bucks and easy install.
You probably want to check the emergency kill switch. I have had this same problem on both of my boats. Engine turns over but immediately dies. Possibly try to leave the "key/start button" in the run position and check there is power across the emergency switch.2000 Super Air Nautique
1988 Mastercraft ProStar 190
