2007 - 211 team - great boat
had a problem with ballst pump not working.
no - problem, read about it, pulled out the pumps, checked impellers, 1 was spin out on the center, a second one marginal, third OK
bought all new green replacement impellers.
put it all back together, starboard pump works great.
however both belly and port pumps seem to work in reverse to what should be on the dash.
these 2 fill when switch in indicating emptying (flashing)
and empty when solid on ....
check voltages at connectors ... all 3 are the same
took impeller out on 1 and reversed (didn't think it would make a difference ... and it didn't)
strange ....
it all works, but it would be nice to get back to filling when light is solid, and emptying when light is flashing
checked the forums .... 1 similar problem with 0 responses.
help ??
strange ....
help ??
