The mr clean eraser won't harm your vinyl but be prepared to do everything as it cleans so good! I mostly use simple green MAX with a soft bristle brush I scrub the crap outta it then wipe with towel and repeat! There are some specific cleaners for mild I forget the name but I had one that was a blue powder you put a couple tablespoons in to a bucket of hot water and stir untill it's all clear then scrub seats and rinse thoroughly with water but it can easily dry up your vinyl if it's not rinsed thoroughly!! And carpet doesn't like it much do best to have cushions out of boat using that stuff . Try the sims green max straight up spray it on generously and scrub with brush!
Current '02 sante full '06 updated
Previously owned:
07 San 210
05 Sante
03 Sante
01 San 210
02 Air nautique
00 Air nautique
+ another 15 non nautiques
Find a sunny day and set it in the sun...If you have coushins that you can remove, find a good reflective surface and set them on. I normally use the roof of my white armada or black 300.
Also the cleaning protect suggested will kill your vinyl. you are taking all the protective films off.
This is not true. It absolutely will damage the protective coating on the vinyl. I used ME's on my old Tige and within a year I had cracks all over the place (this was a boat that was hardly ever used and stored inside). ME's are microabrasives. Use them on the paint on a wall and you will se the paint running and coming off. They have their uses, but cleaning boat vinyl should not be one of them.Originally posted by vanislwake View PostThe mr clean eraser won't harm your vinyl but be prepared to do everything as it cleans so good!
Try Malco or the much less expensive similar cleaning agent Totally Awesome from Dollar General.Now
Ive used "Bleach White", its made for white walls on tires, you can find it in your auto parts store. I rinse thoroughly and never had any problems. Works very well.
well ive used Mr clean erasers many times with no issues!! so say what you want maybe if your digging in super hard or perhaps the pads they sell down there in the states are different then up here in Canada, but never had an issue. Again I mostly use simple green MAX. but on those black rubber marks you get when some fool steps in with his shoes on and marks your vinyl, mr clean is the only thing that seems to work.Originally posted by Chexi View PostThis is not true. It absolutely will damage the protective coating on the vinyl. I used ME's on my old Tige and within a year I had cracks all over the place (this was a boat that was hardly ever used and stored inside). ME's are microabrasives. Use them on the paint on a wall and you will se the paint running and coming off. They have their uses, but cleaning boat vinyl should not be one of them.
PS Tige uses crap vinyl in there junk of a so called tournament boat, lolCurrent '02 sante full '06 updated
Previously owned:
07 San 210
05 Sante
03 Sante
01 San 210
02 Air nautique
00 Air nautique
Arrrg MOLD.
What is it the government website says about mold? If you can get it completely dry within 8 hours the spores won't germinate. If you can't, they're gonna. And mold spores are everywhere. Probably gasoline won't even kill the spores if they are down in the vinyl. (Unless you lit it - please don't).Rob
Davies Super Tuff and a Magic Erasure is the best I've seen or used for mildew spots and general vinyl. No bleach, non toxic. Made my 2000 Ski Nautique interior look factory new. Works great on carpet. Even took off belt dressing when I foolishly applied the dressing with the engine cover open.
Haven't had a mold problem, but on the sides of the removable seats I get some yellowing during the year. I take out the cushions and then diluted Totally Awesome with a nylon brush, and some rags, microfiber towel.
