boat ran fine yesterday, now wont fire, help por favor
  • natedog
    • Feb 2011
    • 143
    • New Braunfels, Texas
    • 1996 Super Sport
    its a 5.8 gt 40 efi, tried to crank at the ramp but no fire and i pulled a plug and no spark, checked for spark from the coil and nothing there, replaced the coil and still no fire, any ideas, someone suggested tfi module, anyone have some ideas?
    1996 Super Sport
  • HS
    • Oct 2007
    • 1333
    • Sammamish, WA
    • 2010 SANTE 210 (Sold)
    Check the Kill switch?
    • natedog
      • Feb 2011
      • 143
      • 1996 Super Sport
      kill switch has been bi-passed since i have owned the boat
      1996 Super Sport
      • surroundsound64
        • Jul 2005
        • 2147
        • Longview, TX
        • 2018 230 1981 Ski Nautique
        Get a voltmeter and see if you have juice going to the coil. Just trace it back until you find power.
        2018 SAN 230
        1981 Ski Nautique
        Sold - 2011 Sport 200V
        Sold - 2000 SAN
        • natedog
          • Feb 2011
          • 143
          • 1996 Super Sport
          yea i was thinking of that i should have picked one up when i got the coil since i dont have one and always need a volt meter
          1996 Super Sport
          • natedog
            • Feb 2011
            • 143
            • 1996 Super Sport
            so i tested the tfi module today and its fine and its not the coil, anyone know if the gt 40 can use a ford distributor or does it need to be marine, a friend thought the rotor turned the opposite direction in my boat distributor so if anyone can shine some light
            1996 Super Sport
              • Nov 2025
              I'm pretty sure you can use the Ford car distributor. That said, I would try some more troubleshooting before buying one, especially if you don't have power between the coil and the distributor. Where is the last link in the ignition chain that you have power?
              • natedog
                • Feb 2011
                • 143
                • 1996 Super Sport
                chexi, do you know if there is a main fuse panel on my SS or does all the electronics tie into the breaker panel i have with the 3 red buttons next to the ecu at the rear of the motor?
                1996 Super Sport
                  Do this:
                  http://www.planetnautique.com/vb3/sh...light=Ignition
                  And this:
                  http://www.planetnautique.com/vb3/sh...=Fuel+Pressure
                  There are two cube relays on the back of the engine. Check for power at pin 30 of both relays.
                  This explains it a little further.
                  • azeus17
                    • Feb 2008
                    • 387
                    • Grand Rapids, MI
                    • 2022 GS22 - Coming in July Previous Boats: 1989 Sport Nautique 2002 SANTE
                    distributor def needs to be marine. Regular auto (ford) distributors are not sealed and can cause a huge fire hazard. (spark + fuel fumes = bad day)
                    Do yourself and anyone that rides in your boat a favor and put the correct parts in...yes, they will cost more, but a lot less than your kids life...
                    • azeus17
                      • Feb 2008
                      • 387
                      • Grand Rapids, MI
                      sorry, after re-reading that last post, it sounds like it came off a little harsh...not intended. It was not even directed at the original poster...more just a general statement.
                      • natedog
                        • Feb 2011
                        • 143
                        • 1996 Super Sport
                        thats ok no offense taken, but i talked to two nautique service managers and both told me there is not any difference in a ford car distributor and a marine as they said the car distributors have to seal to keep moisture out as well as marine distributors
                        1996 Super Sport
                        • j2nh
                          • Dec 2003
                          • 628
                          • Spread Eagle Wisconsin
                          Do yourself a favor and check the bypassed safety switch. Unless you are 100% sure that the bypass was made using a solid connection, and not just wires twisted together, this could very well be the root cause.
                          2018 200 Team H6
                          2009 196 Team ZR 409
                          2005 196 Limited ZR 375
                          2003 196 Limited Excalibur
                          1999 196 Masters Edition
                          1987 ProStar 190
                          • natedog
                            • Feb 2011
                            • 143
                            • 1996 Super Sport
                            Just checked the 30 pin on each relay with a low voltage meter and it lights up with the key turned on but nothing from the coil still.
                            there are not any wires plugged into the backside of the safety tether, my guess is the previous owner/mechanic removed all of it.
                            1996 Super Sport
                            • azeus17
                              • Feb 2008
                              • 387
                              • Grand Rapids, MI
                              well, no offence to the service managers...but they sound like idiots. I would not be installing any automotive ignition parts in my boat, nor would I let them. Also, in case anyone is wondering, you should not have an automotive carb or starter. Cars have lots of ventilation in the engine compartment, so fumes do not collect...your boat does not have any ventilation until you either are moving or have turned on the blower...either way, I am not taking that risk. Anyway, if you do not have power at the coil, why are you messing with the distributor...it just "distributes" the power from the coil to the proper plugs. You need to look up stream from the coil.
                              If you still do not believe me...post your question up on correctcraftfan.com or just search their forums...there are literally guys that desinged these systems. They are way better at diagnosing these kinds of issues.
