2003 Excalibur 330 running badly at lower rpm
  • gatorgates
    • Aug 2003
    • 112
    • Springfield, IL
    My 2003 Ski 206 (Excalibur 330) started running poorly over the weekend. Missing/running rough at idle and then missing/running rough on acceleration until, say 2500-3200 rpm when suddenly starts running great. Jumps out of the water like I shifted gears. Will run great for full set but as soon as I drop the throttle, same problem exists. I have owned since new and never had a tune up of any sort and have 400 ish hours. I changed all plugs and the high pressure fuel filter with no effect. Ran a bottle of injector cleaner through it but no help. Neither the check engine light nor any of the other data screens are showing any problem. Any thoughts? Plug wires? Distributor? Nearest dealer is 2 1/2 hours away.
  • AirTool
    • Sep 2007
    • 4049
    • Katy, Texas
    Go read the recall on the "Camshaft Retard" recall and see if you are in it.
    Also, carefully pop your dist'r cap off and clean all the metal fuzzies off the contacts.
    • surroundsound64
      • Jul 2005
      • 2148
      • Longview, TX
      • 2026 S23 1981 Ski Nautique
      Sounds ignition related to me.
      2018 SAN 230
      1981 Ski Nautique
      Sold - 2011 Sport 200V
      Sold - 2000 SAN
      • gatorgates
        • Aug 2003
        • 112
        • Springfield, IL
        I popped the distributor this morning - its dante's inferno in there - with stalagtites and stalagmites of white/grey gunk hanging off of each contact point. If that aint THE problem, it is certainly A problem. Ordering a new cap and rotor. Thanks for the help folks.
        • AirTool
          • Sep 2007
          • 4049
          • Katy, Texas
          Send $20 to ......
          For now, clean that cap and wipe it all those little metal soldiers standing at attention and go have some fun.
          You should still go check that recall notice.
          Report back on the cap.
          • gatorgates
            • Aug 2003
            • 112
            • Springfield, IL
            Scraping the gunk off did not do much good, but a new cap and rotor completely fixed the problem. Back to 100% power. I should have started there, but for some spaz reason I had in my head that my motor was new enough to have abandoned the rotor. Ah, well, new plugs and fuel filter didn't hurt. Now I need to find a way to cut down on the humidity in my boathouse so the new parts dont corrode and my carpet doesn't mildew.
              • Aug 2026
              Some peeps change their cap and rotor every year, along with plugs and wires.
              • laurie88
                • Mar 2010
                • 75
                • model 206
                good call with the dist cap, you were lucky. i had same prob and changed nearly everything out incl cap and rotor.
                mine was cam retard as air tool suggested, i read cam retard update notice and then checked my retard with diagnostics
                and it was 17 degrees out.........simple fix took 15 mins, to loosen distr and turn to correct reading
                • Anmol Hilston
                  • Aug 2011
                  • 3
                  • London
                  • Boat..
                  when it comes time to park it again next year, run it as empty as you can and take it to a shop for a winterizing.
                  _________________
                  software downloads|free download|software
