The saga continues. So here is what is going on. My boat will run fine. Then the rpm Gauge will suddenly redline. The motor will not be racing up, but the tach will jump to past 6000 rpms. Just after this, the boat will lose power, and often stall. We surmise that something is giving the ECM the wrong rpm information. Then when the boat thinks it is going into redline, it cuts fuel or spark as a safety mechanism. This sequence keeps happening, but the problem is intermittent. Once it starts, it keeps getting worse. Is there an rpm sensor that could be bad?
I've replaced rotor and cap, fuel relay, tp sensor, map sensor, idle speed control unit, fuel filter, plugs and wires, and tested both fuel pumps (33 psi) even when the problem is happening.
