http://www.youtube.com/watch?v=2hB2H7BakvA
Above is a link to a youtube video I just posted taken from video shot yesterday. As you will see, my idle (a) seems high when it is not bouncing (800's rpms - 1000 rpms), and (b) bounces sometimes (not always). I also will stall at idle sometimes (not always), and can get some bucking/jerking which may lead to a stall when cruising. Seems to happen more with hot engine. If it is happening a lot, if I stop and wait for a bit, it goes away for a while.
I have (1) replaced fuel relay, (2) replaced MAP sensor, (3) cleaned spark arrestor, (4) replaced fuel filter, (5) tried different batter, (6) cleaned battery terminals and connectors, (7) replaced ground - battery connector, and (8) cleaned anti-siphon screen. Actually, the dealer did the last two.
The video is not straight through. There are several minutes in between parts of the video that the boat ran fine. This is an intermittent problem that neither of 2 dealers have been able to re-create, hence the video.
If anyone has any ideas, please let me know. I suspect idle speed control solonoid (will try to clean) and/or TP sensor based on the diagnostic manual. All of my symptoms (high idle, rolling idle, stalling, bucking and jerking) have the common denominator of idle air control in the diagnostic procedures.
