Originally posted by horkn
View Post
Originally posted by Texan1554 View PostLeave it to the EPA to further support a product that is only available because our tax dollars are used to compensate the value that is actually lost in its production.Originally posted by Kmayotte View PostGrowing the corn for ethanol is basically raping the Earth anyways. The rate at which crops are grown and harvested to keep up with the demand degrades the soil & nutrients. Never mind the fact that it's causing food scarcity and huge fluctuation in food prices across the globe. I think the figure is something like 60% of all U.S. grown corn goes towards fuel rather than food.
2003 SANTE - "OG 210"
As I read the web site I understood it to mean 85% E. What is butanol?Originally posted by horkn View PostThat's been the norm for several years now.
Are you confusing e85 and e15? e85 is 855 ethanol, where e15 is only 15% ethanol. E10 of course is 10% ethanol.2010 Super Air Nautique 210 Team Edition
Alcohol made from butane instead of ethane. It has 4 carbon atoms instead of 2. It still has the OH hanging on the end. Probably equally detrimental to elastomers ( I would have to confirm ) and equally thirsty for water. It would have a higher adiabatic flame temperature and heating value than ethanol...but still not as high as good ol' gasoline.
Originally posted by HS View PostAs I read the web site I understood it to mean 85% E. What is butanol?
e85 is 85 percent ethanol.
I think I typed a 5 without the shift key, so it wasn't a percent sign, but rather a 5.
Butanol has a lot of very good properties, but one negative is that is has issues at lower temps. That's not a problem in a any recreational boat.
Here is some info on butanol.
http://en.wikipedia.org/wiki/Butanol_fuel
The E85B sounds very interesting. It is 85% ethanol, and 15% butanol and acts more like straight up gas than ethanol does. it's 100% biofuel too.
The other interesting thing about butanol is that it can be made in the same way that ethanol is,so it doesn't require a costly machinery change to produce it.
