We have a 2003 Super Air Nautique, there are two tanks in the back that came stock, to fill them you use two knobs behind the driver seat and a empty or fill button on the dash. I am trying to make sure im doing this the right way. Each time we take the boat out one of the gauges says full and the other one says empty. Which way do I turn these knobs and when? Anything else I need to do? We just got the boat back from being serviced and they claimed they fixed the ballast.
Ha, I always forget too. I think counterclockwise is open and clockwise is closed, but I just turn them so there is play either way. That way I know they are open. These knobs open air vents, which will allow the incoming water to displace the air, thus filling up the tanks.Now
Yeah, that's right. My '03 had them under the dash too.Originally posted by Chexi View PostHmm... are you sure you have a 2003? I though the 2003 were under the dash and labeled.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
yeah, never seen the valve handles / knobs behind the driver seat ... did you mean under the dash? the ones under the dash should be labeled open and closed. then, you probably have two long handles at the front of the engine compartment that open and close brass valves down at the thru hull, spin them left for openOriginally posted by C.J. View Postto fill them you use two knobs behind the driver seat and a empty or fill button on the dash.2003 SANTE - "OG 210"
