2003 Excalibur 330 Overheating
  • Peter Wake
    • May 2011
    • 10
    • Burlington Ontario
    • 2003 Super Air 1999 Ski
    I have a 2003 Super Air 210 with an Excalibur 330 in it. I am just getting it in the water this season - I am noticing that the temperature is staying at 175+.
    I have replaced the impeller and checked the strainer to make sure it is tight - I have also tightened all of the ring clamps.
    Any ideas on what it might be?
    Thanks
    Peter
  • swc5150
    • 2240
    • Eau Claire, WI
    • MasterCraft Prostar
    Maybe this is too simple, but it's possibly your thermostat.
    '08 196LE (previous)
    '07 196LE (previous)
    2 - '06 196SE's (previous)
    • Peter Wake
      • May 2011
      • 10
      The thermostat is next on the list - anyone have any instructions on how to replace it?
      • swc5150
        • 2240
        • Eau Claire, WI
        It's really easy. The PCM manual is on the reference page of correctcraftfan.com, or do a search on PN.
        • TRDon
          • Oct 2007
          • 722
          • MN
          Did you ever or has anyone ever dont the water pump recall on your boat. Same thing happened to me last year and I found out there was a recall. The local dealer worked it out with PCM for the part and just gave it to me to install.
          • PHB
            • Nov 2025
            • 20
            I've got the same year boat and the tape on the barb going in the strainer had worn out on mine and was sucking air. Mainly due to pulling the hose on and off to hook up garden hose on mine. They should make those strainers with out so many parts.
            • Peter Wake
              • May 2011
              • 10
              I am thinking that I will replace the strainer and the thermostat....
              • core-rider
                • Feb 2004
                • 1360
                • Huntsville, AL
                • 2003 Black SANTE
                Check to make sure the black o-ring that seals the strainer is there and properly seated. Mine gathered once after screwing the cannister back on and caused enough air to pull and into the strainer to loose water flow.
                Jason
                All black 2003 SANTE
                -- Southern Fried --
                • caverlyc
                  • May 2009
                  • 37
                  • Minnesota
                  • 2008 MasterCraft x2 (current) 2003 Super Air 210 Limited (sold) 1995 Ski Nautique (sold)
                  Water pump
                  Water pump recall!!
                  • TRDon
                    • Oct 2007
                    • 722
                    • MN
                    Did you read my post? Dont start throwing parts at it before you figure that out. If that recall hasnt been done, that is very likely the problem.
                    • swc5150
                      • 2240
                      • Eau Claire, WI
                      He could just pop out his thermostat and drop it in a pot of water on the stove to see if it'll open? It's such a quick and easy test/fix, that I'd think it's worth trying, while waiting for the service appointment date for the recall.
                      • AirTool
                        • Sep 2007
                        • 4049
                        • Katy, Texas
                        Very good point. I hat those hose fittings. I'd like to just cement them in place but it is a bear to get the hose off when you need to so I usually undo the clamp and turn the fitting with the hose on.
                        Furthermore, the mfg of those hose fittings recommends paste on the threads and NOT tape. IIRC, the paste should be non-teflon. I'd have to go look.
                        Anyway, the design is poor. Brass (expensive) fittings might be the answer.
                        • Peter Wake
                          • May 2011
                          • 10
                          I also spoke with a guy at White Lake today who suggested I look for old impeller parts caught in the system. While i am doing that I will drop the thermostat in the spaghetti pot and see if it opens.
                          And I will check on a water pump recall....
                          Thanks for all the ideas - greatly appreciated!
                          Peter
                          • TRDon
                            • Oct 2007
                            • 722
                            • MN
                            If you look at the water pump, the original one will be painted black with the engine. When I got my new one, it was not painted and it was all brass. I cant say they will all be like that, meaning the dealer may have sprayed it before install but I doubt it. It could be a quick easy check.
                            • Peter Wake
                              • May 2011
                              • 10
                              I have replaced the thermostat and the impeller...now it is overheating when at idle and cooling down to 160 when the boat is moving.
                              I have checked the water intake and the impeller - everything looks fine...
                              No sign of any old impeller parts when I changed the thermostat...
                              Very frustrating - looking like I will have to make the 3 hour drive to the dealer....
                              Peter
