First of all, I need this kit http://www.etrailer.com/Trailer-Bear...e/BK2-100.html
Secondly, it does not come with a new flat washer. When I uninstalled my hubs it went castle nut, d ring washer, washer, bearing on front d shaped spindles, but castle nut w cotter pin, flat washer, bearing on rear circular spindles. Is the flat washer simply not needed on front bc of d ring or should I still use flat washer? If so, do you think white lake will have all that stuff? West marine didn't have the right kits.
