convert a pcm file into readable format
  • begunrom
    • Mar 2011
    • 9
    • belgium
    • 2007 Ski Nautique 196
    I just bought a ski nautique 196 from 2007. The previous owner delivered a file with it with the exention pcm. He said that the file contains the latest results of the last motor readout. I cannot open this file, as i do not have the program. I am wondering if someone could print out the information in this file.
  • east tx skier
    • Apr 2005
    • 1561
    • Tyler, TX
    Is it an audio file? That was my understanding of .pcm ... raw audio file.
    • maxxwell
      • Jul 2010
      • 147
      • Houston, TX
      • 2008 Air Nautique SV211 TE
      The PCM file is uncompressed (raw) digital audio file. The file is a direct representation of the digital sample values (1s and 0s) of an audio recording.
      Can be easily converted to .wav or something Windows can read
      Why would the previous owner have engine diagnostics in audio format??
      Gone - 2008 Air Nautique SV-211 Team Ed - Death by Fire
      • h2ohangtime
        • Aug 2009
        • 92
        • Frisco, TX
        • 2002 Super Air Nautique
        Maybe .pcm is just a custom file extension the program put on the file. Did you try opening it with something like Notepad? It could just be plain text.
        • maxxwell
          • Jul 2010
          • 147
          • Houston, TX
          Good point H2O...
          Try to change the extension to .txt
          • begunrom
            • Mar 2011
            • 9
            • belgium
            wrong extension
            The extension was not pcm, but is rec. When i opened the file in a text editor, the following readable lines are shown:
            รกEC_Pleasure
            Engine Part Number: 99999999x99
            Engine Serial Number: 9999999999
            Customer Hardware PN: xxxxxx
            Customer Emission File Name: MGCP_PCM_6POL_59PSI_PROD.005
            ECM Software and Hardware Information:
            ECM Manufacture Date: 8/18/2006
            ECM Serial Number: 3040
            ECM Hardware Number: 1688000-A
            ECM Software Number: 1848200-A
            Current Cal Date: 9/1/2006
            Current Cal Model: 1848500-B
            Cylinder 1 Fire Order: 1
            Cylinder 2 Fire Order: 8
            Cylinder 3 Fire Order: 7
            Cylinder 4 Fire Order: 2
            Cylinder 5 Fire Order: 6
            Cylinder 6 Fire Order: 5
            Cylinder 7 Fire Order: 4
            Cylinder 8 Fire Order: 3
            Total Number of Cylinders: 8
            Engine Displacement: 6,0
            Emissions Calibration CS: 3B23168B
            Total Calibration CS: 89573D7B
            • scuff97
              • Sep 2010
              • 52
              • 1992 sport nautique 2007 SV-211
              That is a Diacom recording. You need Diacom to view and print. I can help if needed.
              • begunrom
                • Mar 2011
                • 9
                • belgium
                yes please
                I do not have access to the diacom program. Can you download it?
                If not, if i would send you the file by mail, could you print it and scan it in?
                • begunrom
                  • Mar 2011
                  • 9
                  • belgium
                  found
                  I just found a diacom update on the rinda website (http://www.rinda.com/update.htm) , that i could use to print the report out. Thanks.
