I was getting a low voltage indication on the gauges on my '07 206LE. Since the battery is 4 years old I decided to go ahead an replace it. So I get home install the battery, turn on the switch and the volt meter is oscillating from up and down from about 9 volts to 12 volts. What would cause this?
I agree. You have a bad ground somewhere.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
The infamous bad toggle switch.Originally posted by causewayskiier View PostI was getting a low voltage indication on the gauges on my '07 206LE. Since the battery is 4 years old I decided to go ahead an replace it. So I get home install the battery, turn on the switch and the volt meter is oscillating from up and down from about 9 volts to 12 volts. What would cause this?
I don't have time now to point you to all the posts. But it's your turn. Good thing for you it is less than ten dollars. Don't scratch the surrounding decal when you change it.
http://www.google.com/search?hl=en&s...&aqi=&aql=&oq=Last edited by AirTool; 03-31-2011, 10:57 PM.
causewayskiier,Originally posted by causewayskiier View PostWhat would cause this?
When you go to check the toggle switch, the up position is for all power. That means the lower "tang" on the back feeds your system. The down position is bilge only and therefore the upper tang on the back of the switch feeds the bildge. The center position is from the battery and should always be "hot". Reach back and wiggle the tangs while you watch your gauge.
Finallly, CC puts a black cable/zip tie from one switch tang back to something else (bilge breaker?) to prevent the switch from rotating. Please tell me which tang your zip tie is attached to. I believe this zip tie is the cause of the switch failures. You may be able to confirm my theory.
Please post back or PM me.
Erratic Voltage
Are you guys talking about the toggle switch below the throttle ie. the On/Off/Bilge pump switch on the side, or a toggle switch on the dash? I have an LE if that matters.
The toggle by the throttle. See decal below. Don't scratch your decal. If you have three holes, it is not available.Originally posted by causewayskiier View PostAre you guys talking about the toggle switch below the throttle ie. the On/Off/Bilge pump switch on the side, or a toggle switch on the dash? I have an LE if that matters.
http://www.nautiqueparts.com/on-off-...rpmedecal.aspx
Here is the switch. I changed brands and is shown on one of my posts. I also mounted a rubber boot to keep the water out. I'll look for that post later. The switch below is factory from White Lake.
http://www.nautiqueparts.com/switcha...lloff3way.aspx
Here it is. Read post number 14.
http://www.planetnautique.com/vb3/sh...-key-pad/page2Last edited by AirTool; 04-01-2011, 10:14 AM.
Eratic voltage
I looked at the on/off/bilge toggle switch and there was no corrosion, and no loose plugs. I re-plugged them all in and put anti-corrosion fluid on them, but I don't know if that did anything. Where would you go next, or should I go ahead and replace this switch anyway?
Originally posted by causewayskiier View PostI looked at the on/off/bilge toggle switch and there was no corrosion, and no loose plugs. I re-plugged them all in and put anti-corrosion fluid on them, but I don't know if that did anything. Where would you go next, or should I go ahead and replace this switch anyway?
It is not a corrosion issue, the tang disconnects inside the switch. Did the voltage move around while you wiggled the tang?
