2000 SAN Ignition
  • 2Tuff
    • Jun 2008
    • 31
    2000 SAN Ignition
    Hey all. I have a 2000 SAN with the keyless ignition. Last year while out on the water, I couldn't shut the boat off with the keypad, had to use the kill switch once I got it on the trailer. I have ordered a new keypad, but was wondering if anyone out there can point me in the right direction for wiring in an emergency key system should this ever happen again. I know which wires to jump to get the fuel pump to run, and for the starter, I am just wondering what color in the harness runs the dash power so all the gauges work. Any help would be greatly appreciated! Thanks!
  • ers906
    • Feb 2010
    • 921
    • Phoenix AZ
    I actually wired a keyed ignition for emergency starting and engine cutting on the engine side of both the keyless pad and the skill switch in case either fails at any point. I will send pictures when I get boat uncovered for next weeks lake trip.
    Eric
    Eric, Phoenix AZ
    G23 550 hp (finally here)
    2002 Super Air
      • Jun 2026
      This is a very good idea. I will be interested in the pics as well.
      • ers906
        • Feb 2010
        • 921
        • Phoenix AZ
        Its raining in Phoenix right now (go figure) so I may not be able to get pictures until this weekend.
        Eric, Phoenix AZ
        2002 Super Air
        • jjgag60
          • Sep 2008
          • 165
          Update
          Did you locate those photo's yet?
          • eseybold
            • Apr 2008
            • 60
            my keyless pad is dying as well. I may just go to autozone and get a simple switch for the ignition and a spring-loaded push start switch for the starter. should only be 3 wires.....positive from battery, starter wire and ignition wire. The positive from the battery will need to split to feed both the ignition switch and the push button switch for starter. I just did it on my 1100 cc dune buggy which has an ECM, fuel pump, efi etc
