I purchased a 2007 220 which had been neglected. It wasn't abused, as it only had 11.9 hours on it, but it had been left out in the sun and generally not well maintained. Trying to get it cleaned up and ready to go, considering that in a sense, it was never really broken in.
Cosmetically, I need to replace most of the sun damaged skins, replace the Clarion Remote, replace one faulty amp, buy/install carpet, replace all Sano pads, buy the removable stern seat, and find a cover. Let me know if anyone has any of these available at a good price.
Mechanically, I had a compression check done when I first purchased it, and the results were: 1-210, 2-210, 3-205, 4- 200, 5-200, 6- 185, 7-205, 8-190. The guys from Nautiques of Orlando who did the inspection felt like this was acceptable, likely considering that the boat has been sitting for a couple of years. They had to replace the battery, but it started easily and ran fine afterwards. Additionally, the belly ballast pump wasn't working, and the water pump was noisy, (impeller moved freely, but I'm a worrier). I'm replacing both.
My question is mostly relating to what can/should be done at this stage in the game to ensure a long, trouble feel life... Oil has been changed, Fuel drained and replaced, and V-Drive/Transmission looked fine. Change anyway? What about cleaning injectors? Would that get the compression in each cylinder a bit more in sync? I understand 10% flux is acceptable, and maybe just running it will help. Other suggestions for essentially 'breaking in' a 4 year old boat? What can/should be changed/replaced, and is there anything I need to do during it's first year of operation to break it in? Thanks in advance.
