Originally posted by shag
View Post
I've never heard of a fuel pump going bad directly due to ethanol, maybe because the pre filter got clogged and made the pump run hot, but that isn't really an ethanol caused issue. Granted the FCC is a specific marine and PCM thing, and cars don't have a set up like this, but still that does not make sense to me unless the quality of the pump was not the best to begin with.
I am happy PCM replaced it under warranty though.
Without E10 gas, our fuel costs would be even higher. Also, you can make more power out of ethanol than gas, but since it burns differently, it tends to get less mpg, albeit VERY slightly. The rate that engines are getting more and more efficient will negate any side effects of the minimally lower mpg from ethanol compared to straight dinsosaur juice.
