engine missfire / popping at my wits end
  • laurie88
    • Mar 2010
    • 75
    • model 206
    excalibur 330 hp 2007 only 400 hrs
    started by no acceleration at hole shot and then picked up, also seem to have idle surge.lost a bit of power on the turn
    Now when i accelerate and get to 1700rpm every time the engine will not go any faster and starts misfire/ popping sound
    changed fuel filters, pumps, air filter clean, plugs, ht leads, coil lead, ran on new seperate tank of gas, put in fuel additive. new distr cap, distr rotor, ht leads, coil lead
    no engine warn light, no overheat, starts first time as usual and idles as normal , no cut out, good compression, good fuel pressure
    anybody any ideas, could it be throttle sensor???.....coil????
    trying to get diagnostic tools,
  • teamseal
    • Dec 2006
    • 415
    • Panama city, Florida.
    • 2008 196, 1992 Shamrock 20' center console, 1965 Rickshaw race boat, 2017 ski 200 H6.
    Did you put a fuel pressure gauge on it?
    • laurie88
      • Mar 2010
      • 75
      • model 206
      missfie
      yes fuel press good 65 psi
      • ClemsonDave
        • Oct 2004
        • 659
        • Glen Allen, VA
        • Ski Nautique 200
        After you run it, do all the spark plugs look the same? Are the all firing? Try going WOT, then shut if off immediately (not run at lower throttle), take a look at plugs.
        Did you replace the ignition coil?
        Promo Team member
        1999 196
        2010 200 Team 2010 200 Team
        2011 200 Team 2011 200 Team
        2012 200 Team - 2012 200 Team
        2013 200 Team - 2013 200 Team
        2014 200 Team - 2014 200 Team
        2015 200 Team - on the way
        • laurie88
          • Mar 2010
          • 75
          • model 206
          misfire
          all plugs look the same did not change coil
          been told by dealer (whom i described symptons to) that it could be the oil pressure sensor, which if faulty can limit rpm and pcm had some probs with them and changed them out??
          could it be p pass problem??
          cheers
          • snowboardcorey
            • Dec 2007
            • 105
            • Minneapolis, MN
            • Past: 1968 Ski Tique
            A bad oil pressure switch could/would put your boat in limp mode, not sure that it would make your boat surge at idle though, that sounds more like a throttle position sensor.
            Sold my boat to buy a house, the house is much less fun.
            • NautiDave07
              • Mar 2008
              • 333
              • Louisville KY
              • 00 SAN210 07 236 TE
              My ZR6 did something very similar and Dealer swore it would be throttle position sensor. They were wrong and turned out to be crank sensor
              00 SAN 210 (previous boat)
              07 236 te sold
              • ffmedic74
                • 835
                • Lexington, KY
                Did you check voltage. I had the same issue...turned out that the injectors were not getting enough voltage due to a bad battery.
                • thekneeboardking
                  • Sep 2016
                  • 9
                  • Manchester / United Kingdom
                  • 2007 196 Limited 330 excaliber With Tower
                  I actually have the same problem where is the oil pressure sensor? So I can swap it, I have changed many parts and still no luck.
                  • Joshua J Rowe
                    • Jan 2017
                    • 85
                    • Columbus Ohio
                    • 1999 Air Nautique GT-40
                    A plugged up exhaust can cause symptoms like that. Not sure what the exhaust system is like on your boat. My exhaust fills up with water. I can imagine if some debris got in there it could plug up and essentially hydrolock itself. Probably a far shot, but something to think about.
                    • homer12
                      • Feb 2016
                      • 584
                      • Indianapolis, IN
                      • 2004 SV211 TE
                      From an old fuel injected Jeep I used to have, this sounds like the same problem. Would totally bog down under throttle. I would start by checking throttle position sensor. You should be able to check volts on that and somewhere you should be able to get what volts it should read at idle and under more power. PCM may be able to provide that. They should also tell you what you should expect to read on the oil pressure sensor for testing it as well.
                      • ally505
                        • Feb 2012
                        • 180
                        • Somewhere cold and wet
                        You've pretty much renewed the whole HT ignition. I'd be checking the alternator output. You can get all kinds of gremlins if the voltage is low. Check for corossiom, bad earths etc too.
                        • thekneeboardking
                          • Sep 2016
                          • 9
                          I have finally found the fault, the fuel pressure was down to 40psi and after swapping for a new one it is now between 55-60 and all the problems have gone.
                          • 93Euro
                            • Feb 2006
                            • 94
                            • California
                            • 2006 air nautique 210 SE
                            I think this is one of my issues also I finally put a fuel pressure gauge on mine and it was at like 46
